 Argh, Idea's on removing a nut that just won't budge.
doom26464
Fiorante
7 posters
Argh, Idea's on removing a nut that just won't budge. Empty
PostSubject: Argh, Idea's on removing a nut that just won't budge.   Argh, Idea's on removing a nut that just won't budge. Icon_minitimeSeptember 13th 2008, 11:51 pm
Okay I am removing the exhaust from the exhaust manifold and 2 of the 3 nuts came off like butter then the last one won't budge. I sprayed it with multiple types of sprays such as wd40, liquid wrench and another one the name slips from my head. Getting up into that area isn't exactly the most roomy of places either so does anyone have any ideas that wont damage the studs on the exhaust manifold.
EDIT: I've been using an impact wrench and wont even budge it.
Fiorante
Fiorante
Number of posts : 1234
Vehicle : frankenstien'd skyline
Registration date : 2008-03-04
PostSubject: Re: Argh, Idea's on removing a nut that just won't budge.   Argh, Idea's on removing a nut that just won't budge. Icon_minitimeSeptember 13th 2008, 11:58 pm
a big hammer never fails
PostSubject: Re: Argh, Idea's on removing a nut that just won't budge.   Argh, Idea's on removing a nut that just won't budge. Icon_minitimeSeptember 14th 2008, 12:01 am
Again, I don't want to damage the stud that is holding it on.
That's why this is so tricky.
Fiorante
Fiorante
PostSubject: Re: Argh, Idea's on removing a nut that just won't budge.   Argh, Idea's on removing a nut that just won't budge. Icon_minitimeSeptember 14th 2008, 12:04 am
hacksaw blade in hand, and cut off the nut, it will take forever, but it works.
doom26464
doom26464
Number of posts : 411
Vehicle : MR-2 GT, Civic SiR
Registration date : 2008-08-30
PostSubject: Re: Argh, Idea's on removing a nut that just won't budge.   Argh, Idea's on removing a nut that just won't budge. Icon_minitimeSeptember 14th 2008, 12:11 am
tap it with a hammer or put the socket/wrench on it and tap it with the hammer. The vibration should help loosen it and knock some of the liquid wrench inside the grooves.
IF not like already said drill, cut, chop whatever to get it out and then just re tap it. Chances are if a impact won't take it off then its rust welded it self together from age and heat
Golks
Golks
Number of posts : 582
Vehicle : '98 Honda
Registration date : 2008-03-05
PostSubject: Re: Argh, Idea's on removing a nut that just won't budge.   Argh, Idea's on removing a nut that just won't budge. Icon_minitimeSeptember 14th 2008, 12:13 am
Heat.
PostSubject: Re: Argh, Idea's on removing a nut that just won't budge.   Argh, Idea's on removing a nut that just won't budge. Icon_minitimeSeptember 14th 2008, 12:21 am
Ah I never even thought of taking a torch to it. Although I am unsure if I even have a torch in my possession.
Maniac
Number of posts : 268
Registration date : 2008-08-10
PostSubject: Re: Argh, Idea's on removing a nut that just won't budge.   Argh, Idea's on removing a nut that just won't budge. Icon_minitimeSeptember 14th 2008, 12:26 am
Torch is your best bet, mind you when I did my exhaust the cat to midpipe was the problem so I cut off the nuts then like 2 weeks later I dropped the cat and the bolts welded them selves to the cat so heated those bastards up and just beat the shit out of with a hammer and replaced them.
But can you get a torch in there easy without burning something else up?
Golks
Golks
Vehicle : '98 Honda
PostSubject: Re: Argh, Idea's on removing a nut that just won't budge.   Argh, Idea's on removing a nut that just won't budge. Icon_minitimeSeptember 14th 2008, 12:30 am
Yeah. o2 sensore seized in my buddies exhaust manifold. torched it nice and red hot and it cam eout like butter.
Cant see a nut and bolt being any different.
PostSubject: Re: Argh, Idea's on removing a nut that just won't budge.   Argh, Idea's on removing a nut that just won't budge. Icon_minitimeSeptember 14th 2008, 12:43 am
Well I go to pick up the engine hoist tomorrow so I'll pick up a torch while I am there so hopefully I will have the nut off right away so I can move on with my to do list. Thanks
I should be able to get a torch in there, I am hoping at least.
PostSubject: Re: Argh, Idea's on removing a nut that just won't budge.   Argh, Idea's on removing a nut that just won't budge. Icon_minitimeSeptember 14th 2008, 1:07 am
buy a huge breaker bar.
Maniac
PostSubject: Re: Argh, Idea's on removing a nut that just won't budge.   Argh, Idea's on removing a nut that just won't budge. Icon_minitimeSeptember 14th 2008, 2:39 am
I thought my endlinks wouldn't come off when I put a new sway bar on, but some pb blaster and a little tap and some light reading while I let it soak and they were so easy.
Best of luck seems like you need it!
PostSubject: Re: Argh, Idea's on removing a nut that just won't budge.   Argh, Idea's on removing a nut that just won't budge. Icon_minitimeSeptember 14th 2008, 2:56 am
I got my exhaust off last weekend. I used a breaker bar and went nuts. Haven't had a chance to put the new exhaust on.
PostSubject: Re: Argh, Idea's on removing a nut that just won't budge.   Argh, Idea's on removing a nut that just won't budge. Icon_minitimeSeptember 14th 2008, 10:35 am
Today's the day, I'm going to try a torch then breaker bar. On the last 240sx I took the exhaust off and it was much more corroded and it came off sooo easy.
PostSubject: Re: Argh, Idea's on removing a nut that just won't budge.   Argh, Idea's on removing a nut that just won't budge. Icon_minitimeSeptember 14th 2008, 8:04 pm
Alright I used a propane torch, heated it up till glowing red and used a breaker bar to finish the task.
Thank you guys, without this off my whole day would have been less than productive.
Golks
Golks
Vehicle : '98 Honda
PostSubject: Re: Argh, Idea's on removing a nut that just won't budge.   Argh, Idea's on removing a nut that just won't budge. Icon_minitimeSeptember 14th 2008, 8:39 pm
woooohoooo.
» argh! clutch fan or daul electric.
» Removing decals
» Removing rust
» Removing rear window tint.
» Ideas for a new car?
