| Engine noise | |
Q-tip Rank 1
Number of posts : 3 Vehicle : 02 SIR Registration date : 2009-09-22
| Subject: Engine noise September 26th 2009, 12:32 pm | |
| Just recently while driving i could hear a little bit of ticking coming from underneath the hood. At first i thought it was my timing belt because its something ive needed to get fixed, but i started driving it today and the noise got a lot worse. It sounds like something is knocking from underneath the hood and it just shakes the car. If i keep accelerating or push on the brakes theres no noise but if im just rolling the noise kicks in. Does anybody know what could cause this? i drive a 1990 civic hatchback | |
| Subject: Re: Engine noise September 26th 2009, 12:39 pm | |
| All your lugnuts tight? sounds similar to a problem I had months ago lol, turned out to be loose wheel | |
| Subject: Re: Engine noise September 26th 2009, 12:48 pm | |
| axle ! that what my car was doin it would shake under acceleration and braking thats it and make a terrable sound | |
| Subject: Re: Engine noise September 26th 2009, 12:50 pm | |
- axle ! that what my car was doin it would shake under acceleration and braking thats it and make a terrable sound
He said it doesn't shake under acceleration or braking though. | |
| Subject: Re: Engine noise September 26th 2009, 12:52 pm | |
| - BLACK wrote:
He said it doesn't shake under acceleration or braking though. opps read it wrong i thought he said other way around | |
| Subject: Re: Engine noise September 26th 2009, 5:54 pm | |
| Fuel injectors or valves? | |
JHMED Rank 4
Number of posts : 268 Age : 33 Vehicle : 88 ED8 Location : Regina Registration date : 2009-08-13
| Subject: Re: Engine noise September 26th 2009, 9:26 pm | |
| - Q-tip wrote:
- Just recently while driving i could hear a little bit of ticking coming from underneath the hood. At first i thought it was my timing belt because its something ive needed to get fixed, but i started driving it today and the noise got a lot worse. It sounds like something is knocking from underneath the hood and it just shakes the car. If i keep accelerating or push on the brakes theres no noise but if im just rolling the noise kicks in. Does anybody know what could cause this? i drive a 1990 civic hatchback
bad CV joint. They are the first thing to go in these cars... axles are soooo weak for some reason. | |
| Subject: Re: Engine noise September 27th 2009, 11:55 am | |
| - JHMED wrote:
bad CV joint. They are the first thing to go in these cars... axles are soooo weak for some reason. x2... change it... if it clicks this is it... [\thread] | |
Q-tip Rank 1
| Subject: Re: Engine noise September 27th 2009, 8:50 pm | |
| - Supra wrote:
- All your lugnuts tight? sounds similar to a problem I had months ago lol, turned out to be loose wheel
yeah it turns out it was just loose lugnuts. all 4 lugnuts were so loose i could turn them with my fingers, but since it was so loud it sounded like it was coming from underneath the hood. thanks for all the help guys | |
| Subject: Re: Engine noise September 27th 2009, 9:12 pm | |
| - Q-tip wrote:
yeah it turns out it was just loose lugnuts. all 4 lugnuts were so loose i could turn them with my fingers, but since it was so loud it sounded like it was coming from underneath the hood. thanks for all the help guys Robby FTW! | |
| Subject: Re: Engine noise September 27th 2009, 9:33 pm | |
JHMED Rank 4
| Subject: Re: Engine noise September 27th 2009, 9:56 pm | |
| - BLACK wrote:
- Q-tip wrote:
yeah it turns out it was just loose lugnuts. all 4 lugnuts were so loose i could turn them with my fingers, but since it was so loud it sounded like it was coming from underneath the hood. thanks for all the help guys Robby FTW! Wow, I failed. =P | |
| Subject: Re: Engine noise | |
| Engine noise | |
