 Fuel Pump Questions
5 posters
CamJohns122
CamJohns122
Number of posts : 1380
Vehicle : '93 Civic Si Hatch, 91 Chevy Sprint Turbo, 85 RX7 GSL
Fuel Pump Questions Empty
PostSubject: Fuel Pump Questions   Fuel Pump Questions Icon_minitimeMarch 5th 2008, 12:27 am
OK so my cars got the engine swap im sure everyone is aware of, B18b for those of you who dont, now with the swap the fuel pump was never changed so i didnt realize until now im underpowered and my performance could be alot better with added fuel then i can adjust my ratio etc.
Does anyone know how hard of job this is or how much a place charges on labour like this.
Also ill incorporate it on this thread as well, does anyone on here know anything about tuning? If so lemme know i got lots of questions like how i can go about doing tihs cause with a new fuel pump and header and shit i wanna maximize my performance and what not
playboyz28
playboyz28
Number of posts : 428
Vehicle : Snap-On Tool Truck
Registration date : 2008-02-13
PostSubject: Re: Fuel Pump Questions   Fuel Pump Questions Icon_minitimeMarch 5th 2008, 12:32 am
I think on your car, you take the back seat out, the bottom cushion that is and should be a panel that you take off and your fuel pump is in there.
CamJohns122
CamJohns122
PostSubject: Re: Fuel Pump Questions   Fuel Pump Questions Icon_minitimeMarch 5th 2008, 12:34 am
Should i be able to do that myself? what precautions or steps should i take
PostSubject: Re: Fuel Pump Questions   Fuel Pump Questions Icon_minitimeMarch 5th 2008, 1:20 am
You will want to be sure to you run most of the fuel out of the lines, by pulling the fuel pump fuse. After that on hook your battery and if it is anything like nissan it should take like 20 minutes.
Thats as far as I remember.
CamJohns122
CamJohns122
PostSubject: Re: Fuel Pump Questions   Fuel Pump Questions Icon_minitimeMarch 5th 2008, 6:30 pm
OK so i should be able to do it myself? Someone told me a shop would charge CRazzzy labour fees to do it
PostSubject: Re: Fuel Pump Questions   Fuel Pump Questions Icon_minitimeMarch 5th 2008, 7:50 pm
Place im doing my volunteer work charges $65 per hour, not cheap!
CamJohns122
CamJohns122
PostSubject: Re: Fuel Pump Questions   Fuel Pump Questions Icon_minitimeMarch 5th 2008, 9:23 pm
I wouldnt mind that depending on how many hours it takes lol if it took an hour lol thatd be fine
PostSubject: Re: Fuel Pump Questions   Fuel Pump Questions Icon_minitimeMarch 5th 2008, 10:17 pm
It is usually done by book price. So that means if the book lists the job as three hours you pay for three hours regardless if it takes more or less time. So yes there is a hourly rate but that how they determine the total job cost and $65 sounds about right. I don't think they would be charging you for one hour.... it should be more. However, thats just a guess. If you want to do it yourself you can do one of two things.
#1. Go to your car, open the trunk, lift the carpet and tell me if you see a metal plate that has some wires running to it and is bolted down.
#2. Check a honda forum and someone should list a step by step on how to do it.
(#1 is based on nissan S chassis, so it may not be your best bet)
cuonger69
cuonger69
Number of posts : 284
PostSubject: Re: Fuel Pump Questions   Fuel Pump Questions Icon_minitimeMarch 5th 2008, 11:29 pm
Unless you're making a significant amount of power that will require you to upgrade your fuel pump , your factory fuel pump is fine.
PostSubject: Re: Fuel Pump Questions   Fuel Pump Questions Icon_minitimeMarch 6th 2008, 12:07 am
If I were you, I would check with the honda forums. Most of us will just be guessing at this point.... as I was about two posts before. Research it, there is a lot of info to be had out there.
cuonger69
cuonger69
PostSubject: Re: Fuel Pump Questions   Fuel Pump Questions Icon_minitimeMarch 6th 2008, 12:18 am
fuel pump is located underneath the rear seat. plug and play.
CamJohns122
CamJohns122
PostSubject: Re: Fuel Pump Questions   Fuel Pump Questions Icon_minitimeMarch 6th 2008, 12:24 am
aight sweet thanks guys and well i just wanna upgrade it cause i went from about like 100 horsepower to about 150 or so give or take and i got substantial more torque and i just think i could maximize on my performance with a new bigger fuel pump
Fuel Pump Questions
» Any QCMA Questions
» Questions about Siast
» SGI Ticket Questions
» looking for a place that services fuel injectors
