| Help figure out the problem | |
+6_.... subbie Marshal 240sxy laynehip Maniac 10 posters |
Maniac Rank 4
Number of posts : 268 Location : Regina Registration date : 2008-08-10
| Subject: Help figure out the problem December 5th 2008, 3:30 pm | |
| I have a whine coming from my car it gets louder as the rmp's increase I think it might be a pulley. It sounds like a JRSC when I drive. What can I check to make sure its not that water pump going. Don't have much time to do anything really with finals right now though.
| Subject: Re: Help figure out the problem December 5th 2008, 3:35 pm | |
| - EP304 wrote:
- I have a whine and coming form my car it gets louder as the rmp's increase I think it might be a pulley. It sounds like a JRSC when I drive. What can I check to make sure its not that water pump going. Don't have much time to do anything really with finals right now though.
i actually just had that problem it was the power steering pump apparantly | |
| Subject: Re: Help figure out the problem December 5th 2008, 3:36 pm | |
| alternators whine when they're about to take a shit.
wouldnt surprise me if it was the case since you have a stereo. | |
| Subject: Re: Help figure out the problem December 5th 2008, 3:38 pm | |
| - laynehip wrote:
i actually just had that problem it was the power steering pump apparantly i had the same problem as well. except mine was my a/c pump. IIRC, you can check this by sitting in one spot and turning the steering wheel, if it starts to whine again thats your problem. doesnt sound like it though | |
Number of posts : 2780 Age : 70 Vehicle : Nothing nice Location : Regina. Registration date : 2008-02-29
| Subject: Re: Help figure out the problem December 5th 2008, 3:44 pm | |
| do you have aftermarket speakers? Mine did that when I changed out the speakers for some alpines | |
Maniac Rank 4
| Subject: Re: Help figure out the problem December 5th 2008, 4:01 pm | |
| First its not power steering it has EPS and my stereo head unit is stock only the rear speakers were replaced with alpines. On other another website they say idler pulley. Now looking at diagram I don't think its the water pump it sounds like the top pulley. I'll take a pic in just a bit have to go to Nemco quickly. | |
| Subject: Re: Help figure out the problem December 5th 2008, 4:15 pm | |
| - laynehip wrote:
i actually just had that problem it was the power steering pump apparantly My 93 lude had the same problem and i found out it was the power steering, now my bro has the problem of fixing it hahaha...how much did it cost to fix in your car laynehip??? | |
| Subject: Re: Help figure out the problem December 5th 2008, 4:18 pm | |
| - WReX wrote:
- laynehip wrote:
i actually just had that problem it was the power steering pump apparantly My 93 lude had the same problem and i found out it was the power steering, now my bro has the problem of fixing it hahaha...how much did it cost to fix in your car laynehip??? you know i would have to find the receipt cause i had to get the rack and pinion replaced to but with the power steering pump, and rack and pinion it came to 2200 or something | |
Maniac Rank 4
| Subject: Re: Help figure out the problem December 5th 2008, 4:57 pm | |
| Alright here are some pics Top pulley sounds to be making the noise which I believe is the idler pulley This is the water pump right the one in the middle | |
| Subject: Re: Help figure out the problem December 5th 2008, 5:08 pm | |
| I don't know how this is supposed to help. Its difficult to see if a pulley is "worn" by these pictures. See if the pulley has any play front-to-back, or side-to-side, or up and down. I don't think it is a pully though.. | |
_.... Rank 4
Number of posts : 283 Registration date : 2008-03-16
| Subject: Re: Help figure out the problem December 5th 2008, 5:49 pm | |
| If its the top one then the bearings inside it might be shot, could be as simple as that. There are ways to check by taking it off and spinning it or something like that. Tho anyone of the accessories can make whining noises so its key to know exactly where its coming from. | |
locked2 Rank 3
Number of posts : 188 Registration date : 2008-11-15
| Subject: Re: Help figure out the problem December 5th 2008, 6:08 pm | |
| How about using a screwdriver to the ear to hear what is making the noise. | |
| Subject: Re: Help figure out the problem December 5th 2008, 9:16 pm | |
| if its a bearing going, spray it with some type of lubricant. spray the bearking while its turning and if it stops doing its thing, you know thats what needs to be replaced. | |
| Subject: Re: Help figure out the problem December 5th 2008, 10:32 pm | |
| - locked2 wrote:
- How about using a screwdriver to the ear to hear what is making the noise.
careful there, Ask krett to see his noise hearing screwdriver... | |
Number of posts : 4480 Age : 38 Vehicle : 99ITR/00 Ej6 Location : southey yo Registration date : 2008-09-05
| Subject: Re: Help figure out the problem December 5th 2008, 11:26 pm | |
| did it just start when it got cold ? cause my old civic made a winning kinda sounded like a supercharger inside it was my water pump | |
Maniac Rank 4
| Subject: Re: Help figure out the problem December 6th 2008, 2:02 am | |
| No it started end of October I've been driving with no music now and hear it now. I know the pics aren't to show whats worn its to show that when I go to order parts I order the right stuff. So the top pulley is the idler pulley right. Thats what I'm ordering first I'll see how much it is here but I'm sure the part guy down in the states can hook me up.
Edit: Damn it the guy is on holidays till Jan. shit guess I'll be getting ass raped by Honda. | |
| Subject: Re: Help figure out the problem December 6th 2008, 3:42 pm | |
| evan, dont waist your money by buying random parts you MIGHT think are the problem. I see so many people come into my work and do that. i tell them. "make sure that this is the problem before your instal it." they put it in, nothing changes and they are pissed off because they are out 80$ and 3 hours of hard work and still have something to fix. | |
Maniac Rank 4
| Subject: Re: Help figure out the problem December 6th 2008, 3:52 pm | |
| I might have tomorrow off of work to look more at it or Monday. First I'm going try and spray some lube in it if not I'm going to take the idler pulley off and look closer at it. I should just take it to Honda I need a valve lash done and well I can never get it perfect so for my money I'll bitch at them till I can barely hear my valves tick.. | |
| Subject: Re: Help figure out the problem December 6th 2008, 4:30 pm | |
| these cars still have manually adjustable valve lash? wow, thats old school technology. | |
Maniac Rank 4
| Subject: Re: Help figure out the problem December 7th 2008, 2:07 am | |
- these cars still have manually adjustable valve lash? wow, thats old school technology.
Ya I know. Someone correct me if I'm wrong but I thought I read in the MK2 VW Golf Service Manual that those valves were self adjusting(Hydraulic lifters whatever) , that was a '92 this is a '04 civic any advantage over either? I kinda miss that little car would've liked a vr6 in it. | |
Maniac Rank 4
| Subject: Re: Help figure out the problem December 8th 2008, 4:39 pm | |
| It is the idler pulley I just removed it and sprayed some lube in there now its quiet hopefully it lasts. | |
| Subject: Re: Help figure out the problem | |
