| Honda advice JDM into USDM | |
| Subject: Honda advice JDM into USDM February 28th 2010, 7:00 pm | |
| Just was wondering who on here has had experience swapping a JDm motor into a USDM Civic or honda in general.
If you could PM me or answer on here i just have a few questions i want cleared up
thanks | |
| Subject: Re: Honda advice JDM into USDM February 28th 2010, 10:35 pm | |
| Yup. What are you swaping in? Didn't you sell your eg? | |
taylorvw Rank 8
Number of posts : 1554 Vehicle : ce9a Location : regina,sk Registration date : 2008-02-22
| Subject: Re: Honda advice JDM into USDM February 28th 2010, 11:38 pm | |
| - lu!$ wrote:
- Yup. What are you swaping in? Didn't you sell your eg?
did you run into any problems wiring it in? or was it pretty plug and play? no eg is sittin in my garage *this is cameron accidently on taylors account | |
| Subject: Re: Honda advice JDM into USDM March 1st 2010, 12:18 am | |
| also if anyone has any b series vtec parts PM me | |
| Subject: Re: Honda advice JDM into USDM March 1st 2010, 7:41 am | |
| Wiring wasn't really All that bad... At first i had no idea but thanks to a diagram I found online it as pretty easy. Depending on the engine And obd conversion or not things change as you know. are you staying in the same oBd? The diagram I have is for b16/18 unless you swaping in h22, k20 or f20c haha, it won't work. But I'll try to find it for you. Ephin and quong (spell check) were great help. | |
| Subject: Re: Honda advice JDM into USDM March 1st 2010, 7:43 am | |
| There are a couple guys in 306 that can help you with the vtec parts... Also ephin may have something... | |
| Subject: Re: Honda advice JDM into USDM March 1st 2010, 11:10 am | |
| i was looking at a obd1 b16 or ls vtec | |
phoez Rank 7
Number of posts : 1337 Age : 34 Vehicle : nokia + xj Registration date : 2008-02-16
| Subject: Re: Honda advice JDM into USDM March 1st 2010, 12:20 pm | |
| i got p30 ecu if u need, obd1 b16a2 | |
| Subject: Re: Honda advice JDM into USDM March 1st 2010, 1:20 pm | |
| swappin motors is all the same regardless if it's jdm or usdm. Just use your stock wiring harness and you should be good. If you have an si all the wiring is pretty much done for you, pretty much plug and play with the exception of a few wires may need to be extended if they aren't already. | |
| Subject: Re: Honda advice JDM into USDM March 1st 2010, 1:36 pm | |
| print it out. will help | |
| Subject: Re: Honda advice JDM into USDM March 1st 2010, 11:58 pm | |
| so the wiring harness just plugs and plays?
i need a wiring harness! anyone got one for sale?
preferrably a vtec harness
im not doing a knock sensor im doing engine management or a phearable ecu | |
| Subject: Re: Honda advice JDM into USDM March 2nd 2010, 12:16 am | |
| when i did mine i used my stock ls harness and cut up the gsr one for the like 5 plugs and just ran the wires to the ecu and re pined the plugs going into the ecu and it worked i was supprised how east it was | |
| Subject: Re: Honda advice JDM into USDM March 2nd 2010, 12:52 am | |
| well i need a harness in general preferrabbly a vtec one because my harness is hacked and whacked from the previous owner | |
| Subject: Re: Honda advice JDM into USDM | |
