| Skyline misfire | |
JSharp Rank 8
Number of posts : 1577 Age : 74 Vehicle : 2002 Yamaha R1, 2003 Nissan 350z, 2005 Yamaha R6 Location : Regina Registration date : 2008-05-19
| Subject: Skyline misfire May 18th 2009, 8:21 pm | |
| My car was hardly misfireing before with a Bosch Super f 7 l c 0 r 2 with stock plug gap of 0.7mm but now that i gaped my plugs to .8 hoping to get rid of all the misfire, its running like one of those north end.......... half throttle skylines jk. Im running 12 pounds of boost So should i just re gap my plugs back to 0.7 even though GTRCanada tells me anywhere from 0.8 to 1.1? Or should i go back to the plugs that came with the car which are NGK Ridiums bcpr6eix which came out of my car gaped at 1.05 ? Which heat range should i be in and what should i gap either the NGK's or Bosch's too? | |
JSharp Rank 8
| Subject: Re: Skyline misfire May 18th 2009, 8:31 pm | |
| I was thinking that i should go back to the NGK's but im not sure and i don't know what i should gap them to>?
Alot of people say .8 and call it a day but the copper core Bosch's are running like shit at .8 | |
| Subject: Re: Skyline misfire May 18th 2009, 8:38 pm | |
| thinking back i think my car only missifired after i put in new plugs. hmm | |
JSharp Rank 8
| Subject: Re: Skyline misfire May 18th 2009, 8:39 pm | |
| Subject: Re: Skyline misfire May 18th 2009, 9:31 pm | |
| maybe with the larger gap, the boost is blowing out the spark? Its a common problem on older turbo'd cars. Maybe not so much on a skyline? sparkplugs are usually good to go for atleast 30,000-60,000 kms. | |
| Subject: Re: Skyline misfire May 18th 2009, 9:53 pm | |
| work with a gap that works with your motor,
also 12 psi and 200ish whp will not need colder-than-stock plugs | |
| Subject: Re: Skyline misfire May 18th 2009, 10:57 pm | |
| You sure your coilpacks are good? | |
JSharp Rank 8
| Subject: Re: Skyline misfire May 19th 2009, 2:09 pm | |
| no, im not sure that they are good other then no red dust! (how would i check more specifically?)
Which would you guys recommend
1) regap Bosch plugs to what they where ? 2) change to the ngk ridiums because they are better for skylines? 3) go by stock skyline NGK's which are PFR5A | |
JSharp Rank 8
| Subject: Re: Skyline misfire May 19th 2009, 2:55 pm | |
| right now i think my heatrange is to cold | |
| Subject: Re: Skyline misfire May 19th 2009, 3:39 pm | |
| check your coils ohms with a multimeter | |
JSharp Rank 8
| Subject: Re: Skyline misfire May 19th 2009, 4:07 pm | |
| Alright, so i once again have all the piping and coils and covers and etc off!
Should i gap the NGK to .8 and throw them in or the Bosch to .8 and throw them in?
OR should i go buy stock plugs
I sprayed both sets of plugs with brake klean and both sets look healthy | |
| Subject: Re: Skyline misfire May 19th 2009, 4:33 pm | |
| I kind of agree with marshal. But i would go buy new stock plugs, make sure they are gapped at stock specs or whatever, and try those. | |
| Subject: Re: Skyline misfire May 19th 2009, 6:04 pm | |
| - JSharp wrote:
- Alright, so i once again have all the piping and coils and covers and etc off!
I sprayed both sets of plugs with brake klean and both sets look healthy sparkplugs dont outright fail. unless you've dropped them or something. I highly doubt iridium/platinum plugs would be "better" for your car, becasue it has been recored that platinum plugs do not like to run rich(as in a turbo situation). Gap your plugs to stock specifications and test, only removing your plugs when the engine in stone cold. Like JP said, chech your coils with an ohm meter. Check for loose grounds as well. | |
| Subject: Re: Skyline misfire | |
| Skyline misfire | |
