| Need your guys's opinions | |
| Subject: Need your guys's opinions September 28th 2008, 8:12 pm | |
| So do you think this could be the reason my supra ran like a bag of shit? Seems as though there is a few sections of gasket missing.. HAH | |
Cody Rank 3
Number of posts : 193 Age : 33 Vehicle : 1981 Malibu 355sbc Location : Regina Registration date : 2008-04-01
| Subject: Re: Need your guys's opinions September 28th 2008, 8:17 pm | |
| That doesn't really help matters lol
I was working on a newer Impala and I changed the lower and upper intake manifold gaskets and it was also missing some gasket, very weird | |
| Subject: Re: Need your guys's opinions September 28th 2008, 8:20 pm | |
| BTW anyone know of a good place I can go to get the injectors flow tested?? | |
| Subject: Re: Need your guys's opinions September 28th 2008, 8:42 pm | |
| flow tested? are you sreious? That kinda alot of work for an old car. rebuilt injectors are dirt cheap. If you use Bosch injectors, I will sell you a set of 19LBS(200CC) injectors for cheap cheap, they are compltely rebuilt and cleaner with new o-rings and everything. I wouldn't worry about havinh them flow tested. when tehy are one the car, adn the car is running, probe the terminals and see if they are getting a signal, or just put a long screw driver to an injector and the other end to your ear, and see if you cfan hear a pulsating when the car is running. that will tell you if they are opperating. | |
| Subject: Re: Need your guys's opinions September 28th 2008, 8:46 pm | |
| Well i cant exactly tell HOW well they are working considering the car never actually ran good at all.. Remember, this car sat for 6+ years. I just dont wanna have to rip it apart again beacuse of something stupid like a shitty injector, you know what i mean?
Im not too sure how well those injectors would work in it that you have. Stock is 182cc. What do you think | |
dr.dub Rank 4
Number of posts : 378 Registration date : 2008-06-18
| Subject: Re: Need your guys's opinions September 28th 2008, 9:24 pm | |
| chances are you got one sticking or somthing like that. just go to bucks and get a harness off somthing and make a little harness and try pulsing them with a battery on the bench. if one is stuck just give it a few taps with a wrench. | |
| Subject: Re: Need your guys's opinions September 28th 2008, 9:26 pm | |
| post a pic of what the injectors look like. and seeing as how they are only a little bit bigger, they would be a nice little upgrade, if your factory ones are either worn out, or were never good enough to begin with(like my car's was). Bosch injectors will swap out for bosch injectors, so if you want them, they are good there. These injectors flowed too much for my car, and I will be scaling down to 17lbs injectors. | |
doom26464 Rank 4
Number of posts : 411 Vehicle : MR-2 GT, Civic SiR Location : Moose Jaw Registration date : 2008-08-30
| Subject: Re: Need your guys's opinions September 28th 2008, 11:07 pm | |
| I had a mainfold like that on my supra. Caused the car to idel very bad,to the point of it dying all the time and became undrivable, and under load it ran like piss. As for injectors, I wouldn't waste the money but I think for a set of 6 to be cleaned and flow tested you be looking at around the 100buxs mark. | |
| Subject: Re: Need your guys's opinions September 29th 2008, 10:47 pm | |
| Put new gaskets in, left the injectors alone. Car runs great now.
Just need to do the timing and then the exhaust and shes good to go. | |
| Subject: Re: Need your guys's opinions | |
