| Ignition FUCK me | |
| Subject: Ignition FUCK me August 12th 2008, 5:48 pm | |
| OK well i thought it was my timing that was causing my car to backfire outta the intake and other such things. Turns out timing is dead on and its the ignition, once i get the car back after having it checked it wont even turn on now and i have no spark,
i replaced cap and rotor and still nothing im thinking either coil or plug wires.
any other ideas as to why it wont spark | |
| Subject: Re: Ignition FUCK me August 12th 2008, 6:14 pm | |
| well like I told you on the phone, I doubt it will be the wires. All 4 wires done't usually fail all at once. If your car has a coil, I'd check that, also, check all your fuses and relays... you never know. So you have no spark whatsoever? I find that wierd, the car worked before takign it into mitsubishi, and now it won't. But I won't point any fingers, I jstu don't trust many people. | |
| Subject: Re: Ignition FUCK me August 12th 2008, 6:31 pm | |
playboyz28 Rank 4
Number of posts : 428 Vehicle : Snap-On Tool Truck Location : Regina Registration date : 2008-02-13
| Subject: Re: Ignition FUCK me August 12th 2008, 11:11 pm | |
| - CamJohns122 wrote:
- OK well i thought it was my timing that was causing my car to backfire outta the intake and other such things. Turns out timing is dead on and its the ignition, once i get the car back after having it checked it wont even turn on now and i have no spark,
any other ideas as to why it wont spark the car was running bad to begin with, barely started, it just got progressively worse and it was bound to eventually not start at all, just happened to do it now. I would like to help you out buddy but looks like you already have your team of mechanics working on it. | |
| Subject: Re: Ignition FUCK me August 12th 2008, 11:20 pm | |
| Get out the multi meter and start testing. Is there any power going into the coil? | |
playboyz28 Rank 4
| Subject: Re: Ignition FUCK me August 12th 2008, 11:23 pm | |
| - Supra wrote:
- Get out the multi meter and start testing. Is there any power going into the coil?
They are all built into the distributer..assembly | |
| Subject: Re: Ignition FUCK me August 12th 2008, 11:24 pm | |
| ah, that sucks. I wish I knew more about those honda's. Im actually suprised in that year they still had distributors.
Sounds like this car has some serious wiring issues.. Was the swap a hack job or what? | |
playboyz28 Rank 4
| Subject: Re: Ignition FUCK me August 12th 2008, 11:29 pm | |
| mmm...it was done right, I think. But sometimes parts fail..even hondas dont last forever.. | |
| Subject: Re: Ignition FUCK me August 12th 2008, 11:30 pm | |
| - playboyz28 wrote:
- mmm...it was done right, I think. But sometimes parts fail..even hondas dont last forever..
Very true, its a machine sometimes parts can last 10 years, sometimes 10 days you just never know. | |
| Subject: Re: Ignition FUCK me August 13th 2008, 2:06 am | |
| so do i pull the coil next and test it or what? | |
phoez Rank 7
Number of posts : 1337 Age : 34 Vehicle : nokia + xj Registration date : 2008-02-16
| Subject: Re: Ignition FUCK me August 13th 2008, 5:13 am | |
| you should answer your phone | |
| Subject: Re: Ignition FUCK me August 13th 2008, 1:31 pm | |
| - ePHin wrote:
- you should answer your phone
lol he was with the lady friend last night | |
| Subject: Re: Ignition FUCK me August 13th 2008, 5:56 pm | |
| I didn't mean to be offenseive to mitsubishi techs, I've just had bad experience, becasue everywhere I've taken my car, something terrible has happened. Get an OHM meter, and check the resistance of each spark plug. if it is within spec, then your wires are fine. Any cracks on teh distributor? Is there any water in there? you never know. | |
| Subject: Re: Ignition FUCK me August 13th 2008, 6:02 pm | |
| - Supra wrote:
- ah, that sucks. I wish I knew more about those honda's. Im actually suprised in that year they still had distributors.
Sounds like this car has some serious wiring issues.. Was the swap a hack job or what? The swap looks like it was done fairly nicely, its just the wiring to the rest of the car. It is all wired with speaker wire if I remember correctly, all the same colour speaker wire. I know that made it a bitch to wire in cam's stereo. So mush that I didn't even want to attemp it. But maybe cam changed that out. keep up the updates cam | |
phoez Rank 7
| Subject: Re: Ignition FUCK me August 13th 2008, 8:16 pm | |
| - Boxyisbetter wrote:
- I didn't mean to be offenseive to mitsubishi techs, I've just had bad experience, becasue everywhere I've taken my car, something terrible has happened.
Get an OHM meter, and check the resistance of each spark plug. if it is within spec, then your wires are fine. Any cracks on teh distributor? Is there any water in there? you never know. well his plug wires never did sit in there snug, they usually came loose. | |
| Subject: Re: Ignition FUCK me August 13th 2008, 8:28 pm | |
| and i always thought vw's were a PITA | |
phoez Rank 7
| Subject: Re: Ignition FUCK me August 13th 2008, 8:34 pm | |
| - JBlack09 wrote:
- and i always thought vw's were a PITA
imo this only happens when you buy a ghettorigged whip. lol | |
| Subject: Re: Ignition FUCK me August 14th 2008, 1:14 am | |
| lol such as the windows of a certain red celica?? | |
phoez Rank 7
| Subject: Re: Ignition FUCK me August 14th 2008, 2:35 am | |
| - JBlack09 wrote:
- lol such as the windows of a certain red celica??
haha no comment | |
| Subject: Re: Ignition FUCK me August 14th 2008, 2:43 am | |
| No the speaker wire was just for when he put in acutaors everything else is fine tho | |
| Subject: Re: Ignition FUCK me August 15th 2008, 3:11 am | |
| WOO HOO got it started today but now its only running off of 2 cylinders? Any ideas? im gonna try replacing the wires to as they look like garbage none the less and theres a sale going on so i can get a good set for cheap | |
phoez Rank 7
| Subject: Re: Ignition FUCK me August 15th 2008, 6:15 am | |
| what was needed to get it running?
and where the fuck is my sig | |
| Subject: Re: Ignition FUCK me | |
