| hub adapters | |
| Subject: hub adapters October 11th 2010, 4:06 pm | |
| does anyone know were i could get a 4x100 adapter to 5x114 ? | |
| Subject: Re: hub adapters October 11th 2010, 4:15 pm | |
| Subject: Re: hub adapters October 11th 2010, 4:55 pm | |
| Subject: Re: hub adapters October 11th 2010, 5:04 pm | |
| hmm maybe its not worth it | |
| Subject: Re: hub adapters October 11th 2010, 7:38 pm | |
| it depends on the rims if you have to cut your studs or not, some styles have slots/spaces that will slide over a stud when you put the adapter on but this is probably rare, its worth taking a look at the rim though, just in case. | |
| Subject: Re: hub adapters October 12th 2010, 10:50 pm | |
| True, but I think that mores apply to when changing a 5 bolt to a different 5, and a 4 bolt to a different 4. Some wheels have spaces between each bolt hole. | |
| Subject: Re: hub adapters October 12th 2010, 11:25 pm | |
| well i wanted to put my itr wheels on a civic but i think i may just get steelies
| Subject: Re: hub adapters October 13th 2010, 2:47 am | |
- well i wanted to put my itr wheels on a civic but i think i may just get steelies
Would probably be easier and better to just get ITR hubs, and associated shit...no? If you can get away with just the ITR hubs, then have the rotors drilled to 5x114.3 (but I bet with a little research you can find an off shelf 5x114.3 rotor that will work with stock civic calipers) Well ok, the other thing that can be done, is a 4 bolt hub and disc can be re drilled and 5 new studs banged in. for 4x100 to 5x114.3 this will work great except for one stud over will 1/2 overlap. So on that one, the hub will need to be filled (welded shut) grinded smooth, and drilled. Most local machine shops can easily handle this. On the rotors, they can just oval that one hole, it doesn't need filling. But the other need drilling, and it needs to be accurate, so it needs to be done by a machine shop with a jig. | |
| Subject: Re: hub adapters October 13th 2010, 8:19 am | |
| i cant use itr hubs civic has drums in the back and its like 1500 to do 5 lug conversion | |
| Subject: Re: hub adapters October 13th 2010, 8:44 am | |
| - Heretic wrote:
- True, but I think that mores apply to when changing a 5 bolt to a different 5, and a 4 bolt to a different 4.
my bad, lol | |
| Subject: Re: hub adapters | |
| hub adapters | |
