| Relocation: Wire! | |
| Subject: Relocation: Wire! August 22nd 2008, 7:57 pm | |
| Alright I am relocating my battery and can't for the life of me remember the place I was told to go to purchase the wire needed. Also what gauge is suggested and should I keep the ground location or ground it in the trunk area? | |
| Subject: Re: Relocation: Wire! August 22nd 2008, 8:38 pm | |
| - corey wrote:
- Alright I am relocating my battery and can't for the life of me remember the place I was told to go to purchase the wire needed. Also what gauge is suggested and should I keep the ground location or ground it in the trunk area?
Are you going to do it to NHRA specs? | |
| Subject: Re: Relocation: Wire! August 22nd 2008, 9:18 pm | |
phoez Rank 7
Number of posts : 1337 Age : 34 Vehicle : nokia + xj Registration date : 2008-02-16
| Subject: Re: Relocation: Wire! August 22nd 2008, 9:25 pm | |
| 0ga and 2-4ga for the fusebox | |
Fuckbag Rank 2
Number of posts : 87 Registration date : 2008-06-18
| Subject: Re: Relocation: Wire! August 22nd 2008, 10:12 pm | |
| 1 ought, and use the same size for ground, and find a good solid chassis member to ground too | |
greddy_1700 Rank 5
Number of posts : 654 Age : 35 Vehicle : 1991 Eagle Talon Tsi AWD Location : Regina Registration date : 2008-05-14
| Subject: Re: Relocation: Wire! August 22nd 2008, 10:20 pm | |
Come see me at NAPA tomorrow, we sell it by the foot, if i remember correctly. We also sell cheap battery box's if you want. | |
Fuckbag Rank 2
| Subject: Re: Relocation: Wire! August 22nd 2008, 10:47 pm | |
| if its being mounted in a hatch back it needs to have a steel or aluminum box mounted to a frame member with 3/8 hardware and have a vent | |
| Subject: Re: Relocation: Wire! August 22nd 2008, 11:07 pm | |
| - Fuckbag wrote:
- if its being mounted in a hatch back it needs to have a steel or aluminum box mounted to a frame member with 3/8 hardware and have a vent
correct, also you need an external battery cutoff switch. Its alot of work Corey, but ask Clark at work he did his the correct way on his talon | |
| Subject: Re: Relocation: Wire! August 23rd 2008, 12:39 am | |
| Hey, I work all tomorrow but next week some time I will stop by at NAPA on my lunch break.
I'm thinking it'd be best to do it by regulations just to be same that way I can never be turned away from an event or something. Is there anywhere with the regulations stated that I could check off to make sure everything is done to a T.
Also should I just use the existing ground then or ground it in the trunk(yes, it is a coupe) Also mounting it to the trunk just drill holes and bolt it? Meaning I will have to drop the gas tank to finish it off? | |
phoez Rank 7
| Subject: Re: Relocation: Wire! August 23rd 2008, 1:46 am | |
| - corey wrote:
- Hey, I work all tomorrow but next week some time I will stop by at NAPA on my lunch break.
Also should I just use the existing ground then or ground it in the trunk(yes, it is a coupe) Also mounting it to the trunk just drill holes and bolt it? Meaning I will have to drop the gas tank to finish it off? you can mount it wherever you want. and you run the shortest ground possible. | |
Fuckbag Rank 2
| Subject: Re: Relocation: Wire! August 23rd 2008, 3:56 am | |
| it has to be mounted to chassis rail. | |
| Subject: Re: Relocation: Wire! | |
