 syncromesh
syncromesh Empty
PostSubject: syncromesh   syncromesh Icon_minitimeApril 6th 2012, 12:32 pm
Who is regina sells/stocks either penzoil or royal purple syncromesh? Doing a full fluid flush/change on everything and this is the missing piece of the puzzle. Need 3 L
Sleypr
Sleypr
Number of posts : 402
Vehicle : 2004 Infiniti G35x, 2000 Jeep XJ
Registration date : 2008-08-30
syncromesh Empty
PostSubject: Re: syncromesh   syncromesh Icon_minitimeApril 6th 2012, 12:46 pm
Den-PAul and Part Source should both have it.
syncromesh Empty
PostSubject: Re: syncromesh   syncromesh Icon_minitimeApril 6th 2012, 12:49 pm
i've found the GM synchromesh works best. most reccomend to stay away from the RP stuff all together
taylorvw
taylorvw
Number of posts : 1554
Vehicle : ce9a
syncromesh Empty
PostSubject: Re: syncromesh   syncromesh Icon_minitimeApril 6th 2012, 5:22 pm
+1 with robbie
go to auto e.
syncromesh Empty
PostSubject: Re: syncromesh   syncromesh Icon_minitimeApril 6th 2012, 6:57 pm
part source said they dont have it, so did canadian tire.
Im looking for penzoil as it the OE stuff used in GM and Chrysler vehicles, even has a chrysler part number on it.
Napa has it and Ill be picking it up tomorrow.
syncromesh Empty
PostSubject: Re: syncromesh   syncromesh Icon_minitimeApril 6th 2012, 9:26 pm
marshall text me what you need exactly and quantity I can get royal purple from denpaul, I have an account so it will save you some cash
syncromesh Empty
PostSubject: Re: syncromesh   syncromesh Icon_minitimeApril 7th 2012, 2:21 am
So by that theory , GM synchromesh is just penzoil in a GM labeled bottle?
Ether which way post up where you end up getting it from my BMW trans needs a fluid change. Not sure if I should go with synchromesh or redline MTL
syncromesh Empty
PostSubject: Re: syncromesh   syncromesh Icon_minitimeApril 7th 2012, 3:25 pm
I always used redline in my BMW, and it worked great, I know alot of people swear by syncromesh though, but ive never heard of people using it in bmw transmissions, I know alot of people had problem with it in subaru transmissions as well.
Thanks for the offer Bogan, i didnt read that until now, I have a buddy at NAPA that got me a deal on it. Ill keep you in mind ofr next time.
syncromesh Empty
PostSubject: Re: syncromesh   syncromesh Icon_minitimeApril 7th 2012, 6:15 pm
I am not sure but i think redline MTL is a replacement for cars that run ATF or other light weight oil in the trans like mazda and honda. I dont think it is a suitable replacement if your trans runs 75 or 80w90 from the factory
EVOXXX
Number of posts : 187
Registration date : 2011-05-08
syncromesh Empty
PostSubject: Re: syncromesh   syncromesh Icon_minitimeApril 9th 2012, 12:45 pm
all the honda guys put gm snchromesh in there kseries on the forums and have great results
denpaul is a truck load cheaper too
doom26464
doom26464
Number of posts : 411
Vehicle : MR-2 GT, Civic SiR
syncromesh Empty
PostSubject: Re: syncromesh   syncromesh Icon_minitimeApril 11th 2012, 8:45 am
depends on the vechile I'd say. I use redline MT-90 in my toyotas always. for my hondas always been GM syncromesh.
syncromesh Empty
PostSubject: Re: syncromesh   syncromesh Icon_minitimeApril 11th 2012, 4:13 pm
So my BMW calls for standard gear oil in the gearbox, like a basic 75w90. It protests a bit going into 2nd when you try to get the shift off fast, which makes me want to use GM Syncromesh.
But it could be it just needs new fluid period, what would I use in place of 75w90? Redline, or GM Syncromesh? And which Redline? What about Amsoil gear oil? I like Amsoil from motorcycle stuff, I would always use it, great stuff. Amsoild sells a Syncromesh and a 75w90 gear oil, and that's it.
Kinda thinking the syncromesh stuff is all pretty light fluid, but then again this car makes all of 12hp so extreme pressure gear oil is probably not even needed.
syncromesh Empty
PostSubject: Re: syncromesh   syncromesh Icon_minitimeApril 11th 2012, 6:08 pm
look on e21 forums.. I know the e30 guys swear by the redline.
doom26464
doom26464
syncromesh Empty
PostSubject: Re: syncromesh   syncromesh Icon_minitimeApril 12th 2012, 6:47 pm
Id lean more to the redline mt-90 or MTL. Gm syncromesh is pretty light Its closer to oil viscosity I belive.
EF_guy
Number of posts : 64
Registration date : 2011-04-01
syncromesh Empty
PostSubject: Re: syncromesh   syncromesh Icon_minitimeApril 24th 2012, 1:00 pm
I've heard good things about synchromesh but am also curious as to why a lot of Honda guys chose it over the Honda MTF new formula?
EVOXXX
syncromesh Empty
PostSubject: Re: syncromesh   syncromesh Icon_minitimeApril 24th 2012, 11:05 pm
my civic had the "new" honda formula in it from the factory and it was notchy as hell i swapped it out at 15,000km for gm syncromesh and it was like the car was shifting through air much improvement
syncromesh Empty
PostSubject: Re: syncromesh   syncromesh Icon_minitimeApril 25th 2012, 12:01 am
yeah i use royal purple
stopped notchy shift engangments and reduced tranny noise
seriously, just pick something you like or what you read on bigger forums not QCA and go with it.
syncromesh Empty
syncromesh
