| Stickky Clutch! help | |
+11... 1eightySX Jhall jdm_itr Rob corey subbie Marshal laynehip Clint Eastwood chungstachung 15 posters |
chungstachung Rank 4
Number of posts : 310 Age : 30 Vehicle : Taffy White Civic Si Sedan Location : Regina Registration date : 2009-09-20
| Subject: Stickky Clutch! help December 8th 2009, 1:48 pm | |
| Well im freaking out cus my clutch is sticking. If i press it in all the way it takes a little more time to pop back up... What can be the problem? I'm thinking its a bad clutch | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 1:51 pm | |
| If it just started happening could be because of the cold, I'm thinking maybe moisture somewhere, freazing? maybe possibly | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 2:12 pm | |
| mine does the same thing in cold as shit weather literally takes 2-3 seconds for the clutch to spring back up when it is cold as shit makes for some interesting/fun driving for the first 5-10 minutes | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 2:26 pm | |
| Your clutch fluid is cold as shit, thus it is more viscos, its going to take longer for it to flow through the lines to and from the slave cylinder. You brake pedal might do the same thing too. Now just think what its like for your engine if you have anything thicker than 0W or 5W in there on cold starts.... | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 3:01 pm | |
| speaking about slave cylinders, when replacing my clutch should i also be replacing the cylinder? | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 4:11 pm | |
| - DEADlogic wrote:
- speaking about slave cylinders, when replacing my clutch should i also be replacing the cylinder?
Nooo. | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 4:17 pm | |
| cant tell if your being serious corey, for real no? | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 4:23 pm | |
You dont need to replace it until it fails... which is rarely. | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 4:37 pm | |
| - Marshal. wrote:
You dont need to replace it until it fails... which is rarely. gotcha thanks marshal | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 5:36 pm | |
| anyway i can fix it or do i have to stick it up? cus man my civic i swear is dieing on me. Little by little, sometimes its hard to shift into 1st gear and into reverse too | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 5:39 pm | |
| maybe the fluid has a lot of moisture in it??
| Subject: Re: Stickky Clutch! help December 8th 2009, 5:40 pm | |
| how do i fix it? lol im a dumbass | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 6:01 pm | |
| - chungstachung wrote:
- how do i fix it? lol im a dumbass
its best to just suck it up i am going on 3 winters strong like this and sometimes my car just wont go into reverse untill you push it back a little when it gets really cold | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 6:12 pm | |
| it is because of the cold weather all my cars do it apparently if you switch your gear oil over to synthetic it isnt as bad cause its thiner but i just delt with it -35 weather is hard as shit on your car thats just a fact | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 7:40 pm | |
| running synthetic already lol damn regina and global warming | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 7:59 pm | |
| lol thats why i drive a pos buick in the winter | |
Jhall Rank 9
Number of posts : 2058 Vehicle : Ruckus/91 MX5 Registration date : 2009-04-06
| Subject: Re: Stickky Clutch! help December 8th 2009, 9:47 pm | |
- running synthetic already lol damn regina and global warming
lol isn't global warming the opposite of the problem your having | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 9:48 pm | |
| true but doesnt it affect the cold somehow? | |
Jhall Rank 9
| Subject: Re: Stickky Clutch! help December 8th 2009, 9:51 pm | |
| hmm im not sure, maybe? i just always thought that global warming was from greenhouse gases eat away ozone layers which then allow too much heat to hit the planet and not escape which then warms the earth?? haha i dont know | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 10:07 pm | |
| - Jhall wrote:
- hmm im not sure, maybe? i just always thought that global warming was from greenhouse gases eat away ozone layers which then allow too much heat to hit the planet and not escape which then warms the earth?? haha i dont know
sounds legit hence why the ice cap is melting | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 10:23 pm | |
| Climate change.... come on. | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 10:41 pm | |
like ryan said, all this causes the earths climate to change, causing colder winters, hotter summers, hot snow to fall up etc. It all depends where you are located. | |
| Subject: Re: Stickky Clutch! help December 8th 2009, 11:12 pm | |
WITTCCCCCHHHHHHHHHHHHHH!!!! | |
| Subject: Re: Stickky Clutch! help December 9th 2009, 9:18 am | |
| lol you guys went from talking about clutches to global warming to climate change....oh booiiiii | |
| Subject: Re: Stickky Clutch! help December 9th 2009, 11:26 am | |
- anyway i can fix it or do i have to stick it up? cus man my civic i swear is dieing on me. Little by little, sometimes its hard to shift into 1st gear and into reverse too
Sounds like your slave or master cylinder may be going. Keep an eye on your fluid levels and check for leaks. | |
| Subject: Re: Stickky Clutch! help | |
